'94IDITurbo7.3
HAMMER DOWN!
now i am working on the tail pipe routing. HAD to remove spare tire for exhaust to work. did not want to do that but not that big of a deal at the same time.
i bought the diamond eye system for the 2-piece tail pipe. yes it is nice b/c you can adjust your exit location, but the spare needs to be removed and the factory hanger for the factory tail pipe is useless. it is not even close to the pipe. the way my pipe is going to exit is gonna end up pretty much the same as it would if you used a one piece tail pipe. i don't have any room to "rotate" the top of the over the axle piece. it is close to hitting my rear tank as it is.
i still find is incredibly hard to believe it when guys say, "i installed a 4" turbo back diamond eye system by myself in 3 hours". first off the diamond eye's don't fit good enough for it to go that fast and they have WAY to many joints.
Overall: i am not completely dis-satisfied with the exhaust system but i am not totally satisfied either.
on a positive side note: i will have enough 4" tubing to do an open element air filter sometime. i had to cut one of the exhaust pipes. i will document that with pics at a later date.
