Turbo Install
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
MY turbo came in today. looks great.
got it installed in about 3hrs. went really good. was much smoother than i expected.
just have to tweak the firewall some more, "adjust" the bottom half of the DP to get it to clear the trans cross member, and then simply hook the rest of the exhaust up. i should be driving with in the next couple days.
Pics:;Sweet:D:angel:
typ4
Newberg,OR
make sure you retighten the housing bolts after a few runs. You may need to make a bendy wrench to get them all.
thanks
Hey whats with all the electrical crap on the oil line? I think the little one looks like a stock sensor...whats the big one? electrical temp or pressure?
Russ that looks quite nice in there!
'94IDITurbo7.3
HAMMER DOWN!
does anybody know where i can find a 4" to 4" exhaust pipe adapter. due to the fact that the extra piece of pipe that came with my exhaust system is not a true muffler delete pipe i need to get an adapter to use it.
thanks
'94IDITurbo7.3
HAMMER DOWN!
Finally got the downpipe figured out and welded up.
Final weld on dp flange.
The end of the dp adjusted to get it to clear the trans cross member and point towards the rear of the truck
had to make a dent in the first half of the dp for firewall clearance.
Massaged firewall.
pwillis
