zpd307
that lever should be for the timing.
The arm does not reach the solenoid. That might explain why I don't have a high idle. I'll have to investigate this one later...I believe the solenoid on the front side of the arm is for the cold high speed idle isn't it? The arm should be resting against that plunger.
icanfixall states that the "bad" picture is a C6 setup. Your signature states that your wife's truck has a ZF...was the ZF a transplant?My wifes truck had the same problem about two weeks ago. The throttle cable looked exactly like the one in your "bad" picture and she had the exact same symptoms as you describe.
We brought home a junker 85-6.9, supercab 4x4 a few weeks ago and have been going through hell getting it all tuned up. So many little things are going wrong
Anyways ours was setup to match the manuals layout in that a hefty spring goes onto the cables arm, not like that "wrong" picture you showed. I don't know why that hole is there, my schematics don't show anything going there.
Also there is another spring that goes from that top hole, towards the post at the front of the engine, for that tranny c6 arm. The schematic shows a different shaped, lighter spring?
Ours was just twisted in place and its almost paper thin, I am thinking not original. So we will have to investigate this further, in that I assume this spring is meant to hold that c6 bar forward until there is throttle action?
Also we had a terribly hard pedal with little feedback on this setup, and once in a while it hung up. We inspected the actual throttle pedal assembly and it is kind of weak down there, but we didn't have any major tweaks.
When inspecting the cable closely though, which looks newer, we could find just how bad it was binding up when routed, even though the cable ends looked clean and sound. But check the area the cable rides on inner metal cage and ours cut a hole in that, leading to it having a very rough path. When we took away the spring under the hood, the pedal was still rough and notchy.
A cable is like $43 at kragen. I have seen numerous people also mention there may be what appears to be some cable slack with aftermarket cables, and you should probably spend the time to shim these a bit near the pedal, to minimize the freeplay.
I hadn't tried the cruise control yet, but if what you say is correct, that's another good reason to get the cable taken care of.cruise control. follow the cable over to the driverside on the master cylinder.
I'll be sure to keep this in mind when I install the replacement.The cable can be "adjusted" by bending the mount thats on the intake horn. Usually bending it back towards the firewall is whats needed.
