02AutoWag
Real quick post while on lunch break...
-Tried to start the new truck last night.
-It fires off then dies. Seller stated it was low on fuel, so I figure I was fortunate to get it into my driveway before it quit (when I purchased it, it was too late in the evening, too cold, and I was too excited to remember to drive it to fueling station...probably too stupid too).
-I get 9 gallons in the tank and suddenly the fuel pedal pops and goes limp.
-I reach down there and confirm a slack cable. Go to my good truck and feel what it's supposed to be like.
-I also pop the hood and take a quick visual of the engine side connection. See pictures I took in the morning comparing the first pic (Bad 6.9) to the second pic (good 7.3).
Bad slack pedal/cable:
Good pedal/cable:
Does a limp pedal with slack cable mean the truck will not start?
Things I noticed:
1) On the drive home, the pedal was really low to the ground with very little movement. I did manage to get to 65-70 MPH with the 3.55 C6.
2) The piece with the spring that pushes against the plunger...is also attached to the threaded rod. That contraption looks different in the pictures, why? Bad 1st picture is a 1987 6.9, Good 2nd picture is a 1989 7.3.
3) Any hints/tips on what broke? Pedal side or engine side? Mind you, I am not in front of it and only got a quick look to take the pictures.
3) Any hints/tips on getting it put back together?
Figured I could get more insight on a Friday rather than during the weekend. I'll get my hands on it this weekend, but would welcome any thoughts.
Thanks in advance.
Good pedal/cable:
Things I noticed:
Thanks in advance.
