Big Bart
Tow&Slow
That is a dramatic angle on the drive shaft. Makes more sense now that you would have vibrations to the tranny.
You may want to go double cardan on the tranny end if getting a new one. I believe that means the axle would then be rotated to be in line with the drive shaft.
Might be worth a call to Tom Woods shop.
Driveline Geometry 101
Driveshaft Angle Explained This video will demonstrate the proper angles for a drive shaft in a stock Jeep or Truck and how the rules change when you add a suspension lift. The video below demonstrates what is happening to the shaft at different angles, how improper angles can cause speed...
4xshaft.com
