87 Crew Cab Project
freebird01
Post Turtle!
Fort Wayne, IN
Not much to tell as of late... Got the gooseneck plate off the frame and torched off some misc brackets that I think went to a fifth wheel hitch.
Today I pulled the wiring harness back to the cab and pulled the front fuel tank out in prep for frame and fuel tank painting.
This is not my truck but these are the colors I've decided in. Going to keep the original paint scheme but the colors will be 2012 f250 colors...
freebird01
Post Turtle!
Fort Wayne, IN
Well today was productive... After a disappointing soccer game I came home...put a second coat of Spackle on my bathroom and started tearing into the truck.
Pulled both fenders...managed to drop the hood on my head...no sense was knocked in or out...just stars....many many stars...
Swapping out the radiator support for the 86 core support... Didn't feel like pulling and draining the radiator
Started putting on the 86 fenders...
See how far a brick nose hood extends past the bullnose fenders...
I need to get a nicer hood but put this one on just keep the motor dry...
Lastly I managed to get the visor pulled off.
Next step is get the bottom fender mounts modified on the cab and get the body panels all lined up so I can drill holes for all the xlt trim..
junk
Paullina, IA
The bullnose looks good! The brick nose are the ugliest front end on these trucks if you ask me. Amazing how far that hood sticks out. No wonder the bullnose are tough to intercool.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
No visor? That's crazy talk. I never realized how much more a brick has on its nose.
Sent from my 0PJA2 using Tapatalk
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
One difference is, the sides of the hood above the headlights, angle back, a brick, well like a brick, is flat across the front. I bet if you measured from the cowl to the center of the hood, down the "ridge" in the center, they would be close to the same length......
freebird01
Post Turtle!
Fort Wayne, IN
Nope....the brick is definitely longer. A brick uses extension brackets on the bumper...where the bullnose bumper bolts directly to the face of the frame rails.
subway
be nice to the admin :D
York PA
Looking good, painting is something that I never really learned to well. Your truck is going to looks sharp when it is done.
freebird01
Post Turtle!
Fort Wayne, IN
OK time for an update... Since I was stuck at home for the 4th I managed to get some work done on the truck.
Swapped the drivers side rear door to a cleaner one...has a few dents but less rust.
I also pulled the fuel tanks. I got the front tank cleaned and painted....rear tank is being replaced...
Also managed to wire wheel and paint the rear frame...along with the outside of the rest of the frame.
Its only rustoleum semi gloss black but its better then nothing...
Next up is some repair work to the rear axle....wheel seal..new brake shoes... Pinnion seal...reseal the diff cover and change the fluid...
are you going to be doing any rust repair?
i have some rust free panels, if so
freebird01
Post Turtle!
Fort Wayne, IN
Ok so here we are...kickin a dead horse. time to resurrect this old horse...
i know this is an old thread but im finally back to working on the truck.
I got it into my garage and started striping down the cab.
I built a rolling stand to hold all the acres of doors...
Ended up having to replace the drivers side cab corner...lower door post... and a 6" square section of the floor pan...
I ended up buying a steel cowl induction hood from goodmark through Summit Racing...
got the cab in primer
it will be a factory 2 tone with the primary color called ginger metallic and the center color is driftwood beige metallic. it will have all the early XLT lariat chrome,
no that is not tri-tone. it is just the way the light hits the paint.
still a lot of work to do... but thats the jist of my rebuild so far.
freebird01
Post Turtle!
Fort Wayne, IN
Sorry guys i keep forgetting to come back and update this thread. I will try and do that this weekend. Truck isnt done but it is further along.
junk
Paullina, IA
Awesome man! looks great! Love the colors. I'm glad to see you keeping progress going. It's a huge project.
BagdadRon
