Injector line clamps?
Dustyman
Northern Michigan
I redid my return lines and had to replace #8 line because of a hood/cowl molding being all messed up and letting water drip on injector. So anyway.... I noticed there were spots on the original lines that there were obviously clamps at one time, and all of mine are gone. Is this a problem I should worry about?
lotzagoodstuff
Carmel, IN
+1 on needing clamps: the lines will crack without them as the diesel “paint shaker” tends to work harden them if they move around too much. My 300SDL managed to crack a line even with the injector line clamps in place.
ROCK HARVEY
Dayton OH
You can buy a cheap set of clamps for $40 on amazon. I definitely do not recommend the cheap Amazon injection lines, but the clamps should be good to go.
BagdadRon
