Austin86250
Having some lack luster performance out of my 085 turbo low power high egts
Justin recommend I out a .68 AR housing on vs the stock .96 should wake it up a lot and most importantly down low
4psi is all I’d see driving normally 10psi MAX didn’t want to really make much for power til 2500
Horrible egts towing up hill
This is with a 90cc pump and r and d cam
Biggest challenge with new exhaust housing is the need to make a new custom down pipe
Incoming rant
If you know anything about the 085 kit the down pipe is a slip fit cast into the turbo just horrible.
Getting this apart was pure hell had to sawzall the down pipe in 2 becuase it wasn’t coming out the way it should, and the turbo and down pipe combo wasn’t coming out in truck in one peice.
Then the turbo comes out first thing great turbine wheel is chipped new one of those, great damaged the compressor wheel on removal new one of those, might aswell do bearing and seals while I’m in there
The exhaust housing was so rusted/ seized every bolt snapped or had to be cut off
Then to get the turbine wheel and heat plate out of the housing I had to heat it up as hot as oxy acetylene could get it and and whale on it with a hammer.
So went from a quick day project to now going to be atleast 2 weeks and a whole turbo rebuild but oh well that’s the way it goes
So that’s my rant
Waiting on parts currently but am excited to see what this will do for it
Will keep updated as progress continues and parts arrive
Incoming rant
So that’s my rant
