Dirtleg
Well after waiting what seems like forever I started installing my turbo. My internet connection (satellite yuk) is horrible. It took me 40 minutes to get to the new thread page. Oh well back on topic.
So far everything has gone very easy. Things that are done;
Turbo installed. Had to play with the intake and exhaust housing clocking to get everything to fit but it wasn't hard.
Fuel line rerouted away from turbine inlet pipe. I just happened to find a single port return line cap on one of my spare motors and swapped it. I put a tee inline between those injectors for the return line crossover.
Wiring harness rerouted around the front of the intake manifold under the throttle and cruise cables.
Turbo oil line feed connected to back of drivers head oil galley. I probed the area for sediment in the oil galley and was pleasantly surprised that it all came out grit and gunk free.
Adapter plate made for glow plug relay. This screws onto the bracket that holds the top of the oil dipstick. The relay then bolts onto it. Rerouting the harness put all the wires near here so it will all bolt back on without any wiring modifications.
Rather than bend down the body seam on the firewall I cut out a section of it to make space for the exhaust pipes. I am pleased with the space available there now.
Downpipe is almost done. I took a 2 1/2" header flange and ground it down to fit on the factory turbine outlet v-band. I then cut the flange section of the header flange off and welded it to a 2 1/2 to 3" reducer which I had cut down to be super short. The total lenght of 2 1/2" pipe is about 3/4" before it goes to 3". I then started working on getting the flange angle to downpipe relationship right so that the pipe will fit down the hole when bolted to the turbine outlet. I would have been done with this part by now but I am working alone and it's very difficult to position the downpipe and get measurements at the same time. As such my 3rd attempt got me almost there so it looks like a 4th attempt is inevitable. Probably another 30 minutes on this.
Another shot with the downpipe very close to where it need to be.
I still need to fabricate the exhaust once the downpipe is complete. I have a 3 to 4" reducer and some 4" exhaust pipe as well as a 4" over the axle pipe I got at NAPA.
I also need to make a modification to my valve cover to mount the CDR. I could run a RDT but I don't want to. I figure it would require a hole somewhere as well so I'll just figure out a way to make the CDR work. If anyone has a nice version of this that they want to share that would be great.
I am planning on running it initially with the IP the way it is until I am sure everything is working properly. Then I will turn it up some. I am saving my Moose Pump for when I get a new motor built up.
So after a few more items are knocked out it should be running again. I haven't been able to work on it today due to a Migraine but it is about gone so I should be able to get back to it soon.
Wish me luck.
Wish me luck.
