tjsea
Technically the shims won't affect lift because we have hydraulic lifters. At least not unless there was so much shim in there that the lifters would have no preload in which case it would have had a lifter tick since the first start. The idea with a hydraulic lifter is that the oil takes up the slack or clearance in the valve train. My thought is the shims are probably to make up for however much was taken off when the heads were surfaced in order to keep preload on the lifter the same as before the heads were surfaced.
