derjackistweg
QUOTE=rowingdude;756599]Any ideas on a complete kit (pump, injectors, turbo kit)? That way we can go buy a junkyard IDI, dress it up nicely with new gaskets, studs, etc, and then apply all this goodness to it!
Also, I was curious about the exhaust manifold, is there a reason the turbo has to be placed where it is? Can't it be run to the side like in every other turbo application? I know this would mean moving the passenger side battery, but I was just curious.
Thanks[/QUOTE]
The turbo at the side should have the up pipes left and right with the same length. That's probably not possible if not on top.
Also the vans have less room in the front but ford, of course, dos not want to engeneer two designs.
+ as mentiond aboven- a so called kid that exists only in theory is not more than that!
First we should see the output
+ How much m/g
+ what temperatures, oil and water and cylinder head and egt
+ deliverability, like how good is it to drive, turbo leak
Thanks[/QUOTE]
+ How much m/g
