My 6.9 has been getting warmer as the temps get warmer. But a bit uncomfortably now that I have proper gauges.
Truck is a n/a, new moose IP and injectors in the last 10k miles, has a big superduty exhaust off of what I think was a 6.0 but I'm not sure its 3.5" from the y pipe back with just a muffler no weirdness.
3.55 gears 4x4 and has an aftermarket under dash ac system with a giant condenser in front of the radiator.
The truck absolutely pukes black smoke at wot but clears up as soon as it gets moving and isn't being lugged. This pic is going 65-70 on a 90 degree miserable day with the ac on max.
What's odd to me is hills or not if I'm at 2400 rpm going 65 when the temps are around 90 it will get up to almost 210. But if I lug the thing going 40 on back roads uphill or just idle in the same miserable heat ac blasting etc?.. 195
Egts dont look crazy. I'm guessing just too much fuel still heat soaking the coolant but the egts aren't higher than my 7.3 which is a crew cab, weighs 2700 more, and just always is at 195 even hauling 7k of case tractor and trailer up a hill with the ac on. Or 2 tons of gravel in the bed the other day.
Thoughts?
Thoughts?
