TheBirdman
Actually if I could put forward a silver lining: now that we know yours has been working fine since then, Im a bit less worried about getting the preload perfect. Thinking about things, I dont think theres much damage that could be done by having it a bit loose, aside from shifts perhaps being a little sloppy, or having a bit more rollover noise from the gears rattling. The way helical gears work, as they torque up, they change a lot of the force pushing away from each other into lateral force, so under torque, they are still pushing themselves into the tapered bearings. What does the synchro chatter sound like? How badly were the synchro rings worn before you put it together? A few of mine had some pitting, but it didnt seem too bad to me.Holy cow I just went back to the manual since I apparently didn't get that part, and you're correct. There's no way to measure pre-load with the shims installed, it has to be with them out and you do the math for pre-load. Great. Well the transmission works OK as-is, but the synchro cones are too worn and still chatter. I guess I get to tackle all this again someday, assuming there are real shims on this planet.
As for shims, Im going to take the old shims to a trans shop tomorrow morning and see if theyve got anything close, otherwise another idea a buddy of mine turned me onto was having some shims laser cut from flat shim stock. Where theres a will theres a way. Worse case scenario, I could see myself adding some wax paper shims to the countershaft, thats how you set the axle tube to wheel bearing clearance on a swingaxle vw beetle.....crazy nazis....
