Project Big Red
How do I change the yellow one? Is that a pull the tail housing off the tcase thing? Just never had to mess with one.
A google search and a video tells me I probably need to change that gear too. Might as well change the tail housing seal at the same time.
david85
Campbell River, B.C.
Are you sure it has to be drained? Seems like the fill plug is lower than the output shaft.
tjsea
Lickdale, PA
Yep, easy to do if you have a bw1356 transfer case. Like was said hardest part is pulling the drive shaft. I'v never had to drain the oil. Just a funky clip holds it on to the output shaft too.
zemmeron
