idiTravelAll
Looking good! Why the water to air ic though?
why not?
seems to be doing its job so far.
I gave it a good push today.
didn't get above 900
I was bangin gears too![]()
Also because that is what came with the engine I bought. [emoji16]
you don't have to cut your core support up but you do have to mess with water lines and a pump.
why not?
water to air is very good for drag racing as you usually only need a reservoir that you fill with ice and water for a single pass. For street driving you need a radiator for the water to cool down from being exposed to the intake charge. Overall its a tighter package and much more efficient than air to air due to the characteristics of water, and it can work very well in a street application when the system is designed properly![]()
Yep, you did well with this build, I doubt you'll have any issues with it. Have you put a temp gauge on the reservoir to see what it's staying at?its got its own cooler, fans, and water pump.
As much as it pains me, I think you need to remove some coating at the mounting points
