Coolant Filter Mod - Where is it??!!
ericboutin
Boiling Springs, SC
Alright I'm sorry to ask but I know it was here and now I can't find it....where is the write-up on the Coolant Filter mod? I'm thinking I may tackle that this weekend. I've got the original (i think they are 5/8") hoses on my truck with the original "T". Anyway they are finally starting to crack and weep...so now is the time but I can't find the stinkin write-up. :dunno Thanks in advance.
ericboutin
Boiling Springs, SC
Thank you Thank you!! I am officially losing my mind!! cookoo I knew it was here but for the life of me I couldn't find it! I was re-doing my search when you chimed in. You da man! ;Sweet
Dsl_Dog_Treat
Decatur,MI
Yer welcome!
Concentrating a little too ******* that coffee and doughnut there buddy? ;Poke
If your refering to the "T" in the return line from the heater that goes to the bottom of the radiator just delete that bottom line... Its supposed to warm up the trans cooler faster on the auto trucks. That is not worth using. The line is around $100.00 from Ford too. When you pull the bottom hose adapter you will see it has about a 1/8th inch hole drilled thru it... Not much coolant getting thru that.....
