onetonjohn
Been having what I thought was fuel drain back. Been fighting this for a while, can't find the air leak. I think it's the return line from the junction on the back of the engine back to the fuel tank switch. There is some moisture (maybe not wet, but not dry either) on and around the switch. Let the truck sit a couple days, and I need to crank crack lines bleed to start.
Fast forward to today. Went though the process, got it running - seemed fine. Drove it a couple miles, parked it while I met with some friends maybe an hour.
Got in it fired right up, ran for a sec, then dies. Not like it had before where it ran for a second. This was running for like 10 second normal, then ramp down to diying - won't stay idling.
Did this a few times.
Fuel pressure at shreader valve.
Floor it, and it will stay running at high RPM. Till you let off pedal then it dies.
I was thinking injection pump.
So I pull the filter and put in ATF thinking this may lube injection pump.
Starts a coupe times with same symptom starts runs, but won't stay idling. Then it wouldn't start. No pressure at shreader valve.
Tow it home.
The no pressure at shreader valve, makes me think the ATF plugged the filter, or the lift pump when out.
No idea why / what the need to mash the pedal to the floor to keep it running was from. Injection pump?
Half of me wants to pull the bed, replace shower head, float, fuel lines, switch, injection pump and lift pump. But I"m just frustrated, cause I can't seem to pinpoint whats giving me trouble. The fuel smells old to me - like lacquer thinner, but my friend said it was find. It might be a year old. Any help is appreciated, as I'm at my wit's end on this one. It was good while it was running good, but now it seams like it's all problems I'm having trouble fixing despite spending a lot of time trying to fix it.
Tow it home.
