steelholder
I finally have enough room to do this job. F250 1992 7.3IDI non turbo 143k, I have never done a HG job but have done simpler things like suspension work, swap starters, pulleys,timing belts, replace valve cover gaskets, suspension/brakes, engine/trans swaps etc. The best quote I can get in my area for this job (including the seals and any other preventative work that is easier with the engine out) is around $6k. It's steep, def more than I paid for the truck. I have already tried retorquing the head bolts with no luck.
***SYMPTOMS*** - Almost absent, the only reason I know I have a HG leak is because I can see it bubbling out near the head, close to where the oil filter is located (please see clip). I am positive there is a leak there and its not just something that is leaking from above and boiling at that point. I am not overheating, no water in oil etc etc.
I want to make this truck nice, fix mechanical issue and get it a nice paint job, keep it stock, maybe a slight leveling front lift, keep it for the rest of my life and take it fishing or cruising around on the weekend (maybe that's my answer right there). I have a few questions and concerns.
1. I have heard I need a valve job for job like this but have no idea how or what that is, never done one. Can this be something that can be learned or leave it to the pros?
2. Besides pulling the engine and checking for uneven surface of head, sending to machine shop if so, and adding a new HG what else is there? I'm a big youtube learner and the lack of videos is a concern, I don't have a buddy that knows how to work on these unfortunately
3. Just concerned I will pull engine split it and be overwhelmed I guess.
4. Dumb question alert - what if i just add some high temp epoxy to that are to keep that leak from leaking?
I think this may have happened after using seafoam. I'm not positive but I suspect it may have cleaned out whatever buildup was keeping that leak tight, not sure it matters as it's there now. What do you guys think?
