Blueish white smoke when accelerating
quickster
S Carolina
Take it up a steep hill and see how it goes. If it's a haze, you're ok. If you're cropdusting, it's more than timing. Do the compression and leak down test.
TNBrett
Middle Tennessee
Whether it's actually the cause of the issue it's been good to learn about it.
Decent timing light for these trucks? I'm sure it's much cheaper for me to do it and probably not too hard...
https://www.ebay.com/itm/DTI-Tech-...-/291925919893?_trksid=p2349624.m46890.l49292
This is the one I bought. I believe I offered $180 and he accepted it right away. It’s got everything you need and works well. I did spend a little bit of time with a file and some emery cloth to get the magnetic pickup going into the hole easier.
https://www.ebay.com/itm/DTI-Tech-Time-3300-S-Diesel-Timing-Tachometer-Tester-Draf-530-HMMWV-/291925919893?_trksid=p2349624.m46890.l49292
i keep a drill bit for that very thing.
run it in by hand, makes it pretty easy
TNBrett
Middle Tennessee
The probe itself was actually oversized a bit (about .005” - .010” over 5/16” iirc). I had a spare front cover on the bench to play with too, and with the hole perfectly clean, it wasn’t going in. That’s when I decided to start measuring. I figure the tolerances on the Detroit’s these meters were meant for were pretty loose and it wasn’t an issue. In reality it may be a 8mm vs 5/16” thing.
bilbo
North Dakota
I bought the same one but haven’t used it yet. Mines running good so far but I figured it would be a good tool to have. I intend to check timing this spring when it warms up a bit.
J Mark
Lakewood, CO
This happened to me- lots of blue/white smoke up a steep long hill- and the cause seemed to have been air intrusion in the fuel lines/around the fuel heater. Got new lines and gasket around the fuel heater and no more smoke.... well, no more blue/white smoke at least :)
renjaminfrankln
Raleigh NC
I have one of these as well. Yep you'll have to grind down the magnetic pickup to get it to fit. I used a bench grinder and fine sandpaper to remove any burrs.
gandalf
Senior Member
CA &/or Maine
The DTI timers are luminosity probe only, aren't they? Do they have a pulse pickup which clamps on to an injector hardline?
John Scott
Virginia
Conestoga diesel will rent u the timing light and the pulse meter.... u want to adjust the timing to 8.5 degrees....
RSchanz
Petaluma, CA
Update here:
Replaced CDR valve and it still seems to have that slight amount of smoke when gassing it, it's possibly a little better now. I performed a combustion gas test on the Rad and it came out fine. I also pressure tested the Rad and that came out fine.
Still have not performed leak down and pressure test of block.
quickster
S Carolina
You can re use them if they are still somewhat soft. They are usually rubber. . You can run it with the covers off if need be. Doesn't get too messy. Oil will build up at the drain hole though.
Tyler9828
Staff online
