RSchanz
If you plan on keeping the truck, definitely look into a pump and injectors. But you might want to do a compression check and leak down test. I just went thru the " my truck blows smoke on hard acceleration or going up steeps" blues. I replaced my pump, and injectors and that didn't fix the issue. I did a compression test and had all the cylinders around 475psi except for one. Did a leak down test and I could hear air passing thru the exhaust manifold. That was on the low cylinder. Turns out I had valve recession and bad guides. Had the heads totally rebuilt- new valves, guides,etc. Truck is smoke free now. Just something to consider before you start throwing a ton of money at it.
Thanks for the advice. Actually my plan is pretty much that. I'm going to just replace the CDR valve because it's cheap, easy and harmless. Did you do the compression test yourself? Where did you get the kit? I was thinking of just pulling all the GP's inspecting them and doing a compression test while I'm at it. I found the instructions on how to do so in a Tech article. I think it makes more sense to do this before doing IP and injectors despite the fact that they are kind of an obvious job in the future.
