blakpete91 88 F-250 IDI Build thread
blakpete91
Katy, Texas
Picked up my cab lights from NAPA today. (part number - LIT 25760Y ) Hardest part was drilling that first hole.
Ataylor
Placerville, Ca
Good job on the lights. I put clearance lights on my F250 and it took me 3 hours just measuring to make sure everything was even side to side before I drilled the first hole. I don't think that a truck can have enough lights. Do you have your headlights relayed yet?
Archie
Hmm...now how about a LUND Moon Visor with lights?
As for sway bar I'm sure SOMEONE:sly just may have one up his sleeve, however shipping may be a bit rough!
Looking really sharp so far.
Al
blakpete91
Katy, Texas
Snagged a picture of the nasty storm that blew thru last night (Lubbock, Texas)
blakpete91
Katy, Texas
Long time has passed since I've posted anything on here. Figure it's time for a 6 year update. Started by picking up a set of '03 super duty axles and shoehorning them underneth. Modified a RSK for a 97 to fit the front leaf springs. Also went with some new Cooper Discovery tires on some aluminum 16" super duty wheels. Along the way I managed to pick up some ARP headstuds, 110cc IP, stage 1 injectors, typ4 camsaft, and a stage 1 factory drop in turbo from R&D. The stage 1 turbo(never installed)will be up for sale soon as I've decided to go with Justin's Stage 1 hotside and instead going to use a BWS366 turbo. Water pump bearing has failed on me so truck has been sitting for the last couple of months. Here in a couple of weeks Going to pull engine and pick up a 4wd zf5 speed transmission/transfer case from a friend South of Dallas. Going to take my time with engine before it goes back in as I've only been home for 5 days in the past 2 months because of work. Will try to keep this thread alive with more pics as I make progress.
blakpete91
Katy, Texas
continuation of pictures
blakpete91
Katy, Texas
Stage 1 hotside made it through the mail system ok. R&D intake and BWS366 turbo are only two things I have left to source. Still debating on running an intercooled set up.
The_Josh_Bear
Western WA
You wont regret the charge air cooling! It improves everything. Only downside is the install but after that its cake.
What's the specs on the BWS366?
BagdadRon
