Do not push valve recession out of factory spec unless you want a couple 100lb boat anchors. Been there done that.
I want some more explanation, please. I can't see any reason why it would matter at all, provided you compensate on the upper side for the extra valve stem length.
Is there any decompression gaskets other than the felpros. Or is there such a thing as shims? And btw thanks for everybodies replies so far.
The felpro and Victor Reinz gaskets aren't "decompression" gaskets exactly. They are perhaps .010 thicker than stock... but I once ran into a cheap set of Ford-spec NOS head gaskets, and they measured the same as the felpro ones I've used if I recall correctly. I'm guessing the .010 measurement comes from compression over time or something?
A guy, Jan, over on FTE came up with some "decompression" gaskets which are a good .040" thicker. Three layers of steel with 2 of good quality gasket material.
I bought a set and used them for a bit. It's /not/ a good idea:
1. IDIs don't like decompression. The engine will smoke and be harder to start when cold.
Oddly, I found that with the decompression gaskets, using glow plugs to start it worked /far/ better than ether when I was trying to get things to start the first time(manual setup here).
2. About 1,000 miles down the road, the gaskets leaked on me, leaking compression gasses into the coolant. Did not see coolant going the other way.
Apparently, you should re-torque the headstuds after a couple of heat-cycles, something that the felpro gaskets say you do *not* have to do.
I pulled the gaskets off and could not see any "problems" with them, or evidence that they failed. Put a new set of Felpro gaskets on it, and the problem went away.
Mind you, I put multiple layers of copper-coat on both sides of the gaskets, the underside of the head and the block, just to be sure. There's pictures over on FTE.
