Wastegate adjustment
Cincinnati Guy
Cincinnati, Ohio
I sealed up my crossover pipe, and have no leaks from them. I dont see any soot around where the y connects to the uppipe so apparently it dont leak. I am still only able to attain 4-5psi. Would a bad compressor wheel cause it, or a leak somewhere else maybe, or is my wastgate adjusted enough.
Here is where the w/g is currently at.
The exhaust wheel
Black dawg
sw mt
The exhaust wheel
how much fuel?
egt?
black diamond, wa
Man turn the wastgate up, I have about 3/8"-1/4" or so threads left and it would max out at 11.5...before I plugged it. I think there should also be a jam nut on the rod ?
phazertwo
Die Summer DIE!
Crawlorado!
I don't know much about turbos, and I am sure someone who does will chime in before long, but your hot side wheel looks f'ed
PZ
You need to drill that dimple in the actuator sleeve and the one on the other side till you hit the threads or it will twist off the rod., then add a jam nut if you want.
lewisstevey7
