Trans cooler
FORDF250HDXLT
Maine & Oklahoma
I wonder why none of those pictures ever show the solinoid or circuit boards I have looked at several on the Internet and none show the circuit board?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Ole BlackBetty
Norman, Oklahoma
are you confusing od with lock up by any chance?
What I know is, when I'm going down the highway at 60 mph and turn off the od switch on shifter, nothing changes rpms stay the same. Od is not working, because at 60 mph I'm pushing about 2800 rpm, and before when od was working I was at about 1800 rpm at 60mph
FORDF250HDXLT
Maine & Oklahoma
that's the lack of 4th for sure.see post #76 (the one you quoted) again.i added a couple links to help you test for your issue.
Ole BlackBetty
Norman, Oklahoma
1994 E4OD, transmission shop just told me there is not a shift kit for this trans, only a programmer. Now I know I have seen posts about installing a tugger or transgo shift kit. Am I wrong?
Black dawg
sw mt
I would RUN from any trans shop wanting to use electronics to take the place of a shift kit on an e40d. I have used many e40d with the transgo tugger kit, and they shift very good.
trackspeeder
Stone crusher.
North Branford. CT
Technically the shop is correct. Everybody uses the term "shift kit" for all the newer trannys. But fact they are reprogramming kits.
trackspeeder
Stone crusher.
North Branford. CT
Reprogramming kits are not to be confused with with tuning. Yes, if a tranny shop would do nothing but a stock build and rely tuning to adjust shifts is a no go.
Ole BlackBetty
Norman, Oklahoma
I just bought a new solinoid pack this morning, had a mechanic friend of mine order it,from a transmission supply shop, he uses. The box it is in says 89- 94 application, but the circuit board does not look like the one that is in my trans now. The one in my trans has a green circuit board with visible diodes and circuits and the new one has a black circuit board without visible diodes and circuits?
picture of old board, I will have to get picture of new board later.
Far as color and stuff, I wouldn't worry about that. Most likely just differences in manufacturers.
trackspeeder
Stone crusher.
North Branford. CT
Go by the spec not the color or board layout.
pwillis
