I hadn't noticed that you were in Utah. If you are going up into the mountains around there, then you REALLY need to turn the fuel screw down and advance your timing a tad. Most Bosch pumps have some sort of altitude compensation which cuts back the injected fuel amount and advances the timing above 3000 ft, but Stanadyne pumps are cheap, you need to figure that out for yourself. There is less air at altitude and if you try to shove too much fuel into the engine you are going nowhere, it doesn't make power if there isn't enough air to burn it, in fact you make LESS power than if you had cut the fuel back. You make the most power at the leanest mix possible.Gobs of smoke would only be doing anything if you had 35 lbs of boost worth of air to go with it to actualy make some of it burn, otherwise it's just making you loose power and heat up.
