She swallowed a glow plug
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
Methinks… I will order one of these… 80028 plugs… as well as a 80034, and compare to the Motorcraft 6.9 and 7.3 plugs I have laying around…
Only one of each, doesn’t cost much, and I think I’m $30 curious
Black dawg
sw mt
Do we have any exact application for the 80028? Napa doesnt use the Bosch numbers anymore.
Cant Write
Placerville CO
I have some GP’s (all steel) for 2005 Passat TDI. But I believe they are 5v and would not cross over. I’ll grab a measurement as well.
Black dawg
sw mt
Ordered a couple of the bosch 80028, and also a beru part number of the same plug. Most likely both the same plug. Looking at the pictures of these plugs doesn't look like they will fit. Distance from threads to tapered seat looks much farther.
KansasIDI
Wilsey, KS
Thanks for taking this over. I am sure you are more qualified than I to test these glow plugs, I am going to be away from my home and shop for a couple weeks so this should be a good boost to the research.
Black dawg
sw mt
Mt truck has been showing signs of burnt out plugs, so timing was right to check out some other options. Will most likely put 80034s in it , but if there is a similar plug tbat uses bullet connectors, would be pretty cool.
Black dawg
sw mt
Distance from threads to seat is too far. Won't work.
REM70
