Project: asmith
got the hood on, intake made, and found out I need a different reservoir for the air/water cooler.
just no way to use the existing one without deleting things like hood hinges lol
hope to have it driving this weekend.
didn't make jackisht for progress this weekend.
mama wasn't feeling so hot, so I was on kid duty.
today I got all of my wiring woes out of the way, and gauges mounted and wired.
took all damn day, but it don't help when its 107* outside, work for 20 min and bam... in a pool of sweat.
only 4 things on the check off list!
fix filler neck
brakes and inspect bearings
wire up relays for the fans, water pump, and fuel pump
fabricate a reservoir for the air/water cooler.
then shake it down!
and in a blink of an eye, another month passes, wheres the time go?
took today off of work to finish up a bunch of loose ends today!
got all of the relays, fans, water pump, and fuel pump all squared away.
I had to drop the battery trays an inch so the damn hood would close!
but all is golden now, hood latch is finally in place, and everything works with the turn of the key!
all lights work, and dim's
tomorrow I have to clean up the interior
put kick panels on
fill transmission, and its time to take her for a drive!
