notenuftime
I would like to see these go into production, I would be interested.
Also - I had heard that to turbo these trucks, people usually just flip the manifolds around so they are pointing up instead of down and run a pipe up and over to the turbo rather than down around the transmission the way an N/A exhaust works. Is it actually possible to do that or do you have to run underneath the trans?
I don't think this would work, at least with a stock style turbo.
This is what I had in mind when talking about the differences between a stock style set up and a custom one. And, IIRC, you are running custom made manifolds/headers as well. So, once again, this isn't just flipping the stock manifolds over like IPSKI was told about.with all that work youre talking about to run the pipes over the engine, you can do a TT set up
That's still bigger diameter than the factory up pipe casting!
