lastbugle
My 92 ford 7.3 did something weird has been running OK but yesterday when I went to start it, it started to start then suddenly stopped like froze up hit the starter and it wouldn't turn over like stuck I only bumped it to try but it wouldn't turn over.
for me my first thought was a broken tooth on the starter or flywheel and jammed or water in a cylinder.
So first thing I did was pull the glow plugs and turn it over (which it did so eliminated the teeth on starter) to see if water shoots out a cylinder which it did in the last cylinder on the passenger side thinking crap!, but again heres the strange part for me is there wasn't (A) very much water sprayed out and (B) the water on the hose that got sprayed out wasn't any antifreeze to it my antifreeze is very dark green, plus antifreeze has a kind of film and smell this was just plain water that came out.
I checked the oil no water in the oil.
OK so I put pressure to the radiator put 13 pounds it held for over an hour cranked it over no spray of any kind out the cylinder put the glow plugs back in it fired right up and sounds like it always did but now theres a warning light in the dash says water in fuel I drained it at the filter and the light is still on.
I just don't know what to think of what might have happened?
Any ideas thanks in advance!!
