Introducing MOOSE BOOST!
Heath, is that a standard Banks down pipe or did you have to do some modification to it?
hesutton
The Anti-Anderson
Bowling Green, KY
Yeah, I had to modify the Banks down pipe. The Garrett turbine exit is 3 5/8 v-band with a 3 inch outlet. I ordered a 3 5/8 v-band flange, and v-band clamp, and a tight radius 90 degree three inch 14 gauge aluminized pipe to modify the down pipe.
Heath
Thanks for posting the feedback Heath! I am in the process of getting my custom castings made to make installs go smoothly. Such projects take longer than I would like, but the end result will be worth it.
dunk
Dunce
NJ
Indeed. Curious if this is a complete package more or less bolt on and pricing. When I swap my ZF5 in it'll be time for a new turbo setup and I'd like to pull the engine to reseal and do studs. Rumor a while back was pricing not much more than the big name kits, which would be fine for me as I was looking at a new Hypermax when the time comes.
Pork_Chop50
He looks kinda hairy and slobbery to me....
Willamette Valley, Oregon
Has there been any further development on a ATS/Factory upgrade setup? And while it's been said before there is no such thing as too much thanks. So primarily to Mr. Sutton and Mr. Agne thanks for developing, installing, and documenting m sincere thank you. I am currently a dreamer putting together a long list of updates to my pickup and greatly appreciate there are those whom I can learn from.
olsen726
