What.. No love for a 6.oh.
i wouldnt own one, but i like giving Scott shat
You sure factory is 3.5?
Always looked smaller than the 3.5 on the 7.3. And I don't know if the 6.0 is the same way, but on the 7.3 it's only 3.5 from cat back. In front of the cat it's 3.
Amazon has diamond eye kits for decent prices.
The only reason I'm looking at 3.5 at this point, I am on a budget for this... and I just want to make a clean slice in front of the cat, and the rear of the muffler and drop it out, and put 2 band clamps and a section of pipe in its place. THe stock stuff is 3.5 and I am just wanting to swap out the middle. I may change everything out at some point in time (Turbo back) but the rest of the truck is 100% stock, except an EGR Delete, so a bigger exhaust isn't going to do much for me at this point. I mainly just want it to breathe better, and the muffler and cat have 156,000 miles on it so I am sure it's a bit plugged up, plus I ma starting to notice a bit more exhaust note....
Plus I have a neighbor that doesn't like my diesel truck.........
On my neighbors 6.0 it may have been 3.5, but we didn't measure as we cut the whole thing out.
It also had another cat looking thing built into the downpipe, but can hardly tell it's there because all the foil stuff.
remove the downpipe/cat, remove innards of the cat (if you really suspect it's clogged)
cut out the stock muffler as close to it as possible, flip the S piece around 180 degrees directly in front of the muffler
If you have to pass a visual, get a BTM online for $60, if not get a piece of 3.5" pipe
http://www.summitracing.com/parts/wlk-21470?seid=srese1&gclid=COq6y6edscgCFZWRHwodnn4AyA
For $60 you'll have 80% the performance of a complete 4" system
Back to the sooted up muffler ststement, is there a big problem with this?
Specifically in an idi turbo setup with stock pre turbo pipes?
Can't see a difference in turbo and non pipes?!
