Happy memorial weekend everyone,
Back at it again by doing more stuff to the truck. Working on installing the isspro egt gauge at the moment.
Was curious as to what boost should be with the wastegate wired shut. According to Justin, using mechanics wire is not sufficient enough, but with the 90cc pump I should supposedly be seeing mid to high teens for boost.
So while I wait for the down pipe and wastegate block off plate to show up, I grabbed a really big hose clamp, wrapped it around the boost diaphragm and throw arm for the wastegate valve. Took er for a quick spin, definitely builds boost crazy fast now, but I couldn't get it above 10psi just goosing it around on flat grounds.
For those whose wastegates have left their trucks, what boosts are you seeing?
