TheRadBaron
Hi fellas. This is my first post here. I'm a long time light truck mechanic but I'm new to the Ford/IH IDI (and modifying diesels in general).
I recently picked up a '94 F350 CCLB dually with the factory turbo 7.3. The truck has been in the family for a long time and it's been well maintained and it runs great. It was totally stock when I got it. I've spent the last few months learning about the IDI and I have fresh coolant with SCAs, etc.
I'm doing a VF5 swap and some engine work as well. The truck will mainly be used for towing. I'd like to get a bit more power but most of my emphasis will be on longevity/durability. Here's what I have planned:
-Free flowing intake and intercooler setup from Classic Diesel Designs
-2.75" downpipe from Moose Diesel (cab seam has been clearanced)
-Full 4" exhaust from the downpipe, with straight-through muffler
-Bellowed up pipe and mandrel bent crossover pipe from CDD
-Boost and EGT gauges to monitor things
I've read about adjusting the wastegate for a bit more boost. I've drilled out the punched divots in the factory wastegate linkage so it's adjustable now. I'm thinking that 12psi max will be a good number? From what I've read it sounds like a safe level with factory head bolts. Thoughts? Is that achievable/good idea with the factory turbocharger?
Also turning up the fuel on the IP a bit. Any guidelines on how much to turn it up? IP and injectors are stock.
I have a timing tool for the engine with the piezo sensor that goes around an injector line. Will the addition of more boost and an intercooler, and majorly freer flowing exhaust, have any effect on the timing requirements? What's a good number to shoot for?
Anything else I'm missing or that I should consider?
Thanks.
Thanks.
