pennsylvaniabo
Has anyone here used these cables? Seems like a decent price.
I used custombatterycables.com
Good product and the guy is small time where quality counts!!! I had them in my last IDI and it was night and day from the old cables.
Link:
http://www.custombatterycables.com/application/f350_cables_1987-e99.htm
Thad
holy crap.....at that price I would make my own.....
$75 for one cable by the time you add it all up, you would come out ahead buying a crimper and making your own out of some 3/0 cable You can get crimpers for under $30 these days if you shop around . Bigger batt cable carries current better and spins your starter faster. If you take a little time and make them right,( Quality battery cable and not welding cable, welding cable casing is not oil resistant, saturate the ends with conductive grease and seal the connections with heat shrink tubing ) your cables will outlast a set of factory cables by at least 3 fold
