MUDKICKR
ok im getting ready to pull my 7.3l 5-speed combo and transplant it into my real trk. so i want to rebuild it first(it needs it bad) so where is the best place to buy parts and the best price as well. its an 89 7.3l if that helps. also im going turbo, so i need stronger parts as well. now my plans are as follows, bore out engine to make cyls straight. turn crank and polish it. clean block and replace all bearings. balance all rotating parts. reground cam for turbo? or new cam? shave cyl heads as needed and port match cyl heads to intake,
so what im really asking is what is all the little tricks i can do to get the most out of my trk, its going to be my daily drive and have no less then 40" tires with 4.56 gears so i like all the power i can get but i want it relible as well. thanks for all the replys
