I'm glad that you got that one figured out.
Thank you I am too. Literally has been an off and on issue for a year. It would be fine for months and then leak for a week.I'm glad that you got that one figured out.
My reservoir hose clamp was loose and when pressure would build or burp it would shoot a bit out towards the fan and fling everywhere. Took me a bit to figure out, thankfully I didn't get into testing the rad or replacing.Thank you I am too. Literally has been an off and on issue for a year. It would be fine for months and then leak for a week.
Today will consist of fixing my u joint and pulling his transmission. His clutch only has 10000 miles on it.Haha. That’s why I made sure I bought the 12.25Laine not surprised a guy in his 20’s only got 10,000mi out of a clutch before imploding it.Well at least you just need a u-joint.
Laine I believe you are talking about your front wheel bearings? The trick is if you put in your own races press them in tight with a press. (VS hammering them in.) If not your truck will push them in and your bearings will be loose. Then grease and tighten the wheel bearings, spin a few times. Loosen, tighten, and spin again. You want to make sure the grease is in the way and fooling you into thinking they are tight. Then tighten and release slightly. Then lock them in place. Not sure on your year how they lock but guessing a washer in the middle and a second nut.I put a new U joint in. I jacked it up to spin everything just to make sure everything is good. The passenger side nut that holds the hub/spindle on backed off and absolutely destroyed one of the bearings!!! I have no idea what I did wrong. I torqued it down and backed it off a few clicks like the book said. So now I’ll be pulling the other side apart as well to make sure it’s safe. Then new bearings on the passenger side and I’ll drain all the fluid and stuff. Im very happy that I jacked it up before driving anywhere.
Hahah. I’m not a big drinker. Wish I was then I could explain all the crap I’ve broken. I was talking about the rear end sorry for not clarifying.Laine I believe you are talking about your front wheel bearings? The trick is if you put in your own races press them in tight with a press. (VS hammering them in.) If not your truck will push them in and your bearings will be loose. Then grease and tighten the wheel bearings, spin a few times. Loosen, tighten, and spin again. You want to make sure the grease is in the way and fooling you into thinking they are tight. Then tighten and release slightly. Then lock them in place. Not sure on your year how they lock but guessing a washer in the middle and a second nut.
Maybe you had a bad bearing or maybe it was just the Budweiser working it’s magic the first time.![]()
After further investigation it absolutely destroyed the passenger spindle. Pretty pissed off at myself for not catching it sooner. I think my best option is swapping the guts out of this axle into my old one.I understood that it's the rear end. You mentioned replacing the u-joint right at the yoke on the rear end and then you jacked it up (the rear end that you were just working on) to spin everything to check it all out.
Bummer. Any other clues as to what could have caused the issue. You don't want to repeat that catastrophe.After further investigation it absolutely destroyed the passenger spindle. Pretty pissed off at myself for not catching it sooner. I think my best option is swapping the guts out of this axle into my old one.
