Well figured it’s time for an update since I’ve had my first failure. About 7 miles from the shop I had the throttle cable snap, luckily I was going about 55 at the time, so I just set my cruise control and used that to drive back to the shop. Pulled a used oem one off a parts truck instead of going with another pos dorman replacement, this one only lasted a year or so.
Here’s some pictures of some new additions, bent up a little bracket to mount the nitrous and **** solenoids as well as the fuel pressure regulator. Need to pick up some elbow fittings for the solenoids so the lines have more of a straight shot.
Testing out a product that may be coming out soon, a glow plug upgrade kit. It replaces the stock wiring and connectors with an improved design, replaces the stock relay and controller with a beefy white Rodgers unit manually triggered by a momentary switch in the cab. So far working great, just experimenting with different connectors to see what works and holds up the best.
Here’s a clip I took a while back making a little nitrous pull. Gets up to 60 in about 7 seconds, I think it’s still got more in it with some fiddling but pretty close to being ready for the dyno.
