first allow me to say that I know this horse has been beaten.
im treating this like a straight up rookie that has never worked on a vehicle.
well, because I feel like one.
im ready to slap this on, and because its my third time,
I want to absolutely make sure its my last.
I have permatex's aviation sealant for the timing cover gaskets.
I have Teflon thread sealant for the 4 bolt holes in the middle.
now, for the timing cover to oil pan....
RTV?
I have gray and black.
IP gear housing is bolted and the gear is locked down to ensure alignment.
all my alignment marks are in order.
surfaces are clean and sprayed with brake clean and wiped down.
first order of business.
take the IPGH off, and set it aside.
run a 1/4-3/8" bead of RTV on the oil pan
with the aviation sealant,
brush surfaces of block and cover.
brush surfaces of water pump and back side of the gasket.
brush threads of center bolts with Teflon thread sealant.
allow 20 minutes for it to set up.
install cover, and water pump.
torque to 25 ft lbs
let dry for 24 hours.
RTV ip gear housing, allow it to set up, then bolt it down.
RTV?
torque to 25 ft lbs
