vt951
Throwing in the towel... anybody want my IDI? SALE PENDING
Thanks to all who gave their time and effort to help me with this truck, especially towcat, dsl_dog_catcher, and icanfixall. You guys are awesome.
But, I am officially giving up on it.
I am into this truck about $1100 and can't get it running. Any reasonable offer will be entertained. Truck is located near Cincinnati, OH. PM me if you're interested. I'll only give my phone number and email address through PM.
It is an '86 F-250 SuperCab 4WD Automatic.
Unknown mileage (ODO says 73k, but that could be 273k for all I know)
Body is decent. It was a Texas truck until PO bought it (earlier this year I think). No cancer in the fenders at all. Little bit starting under passenger door. Paint is dull and has lots of nicks. Roof paint is gone (light surface rust there instead). Bed is good except the previous owner cut a big hole in it to put a 6" stack through. Brightwork is all there and good with the exception of the front fender trim has a small dent. Wheels are aftermarket black painted 16" and are in good shape. 3 of the 4 tires appear to be in good shape. The 4th tire is usable, but getting low on tread. Rear part of the exhaust is a hack job and will need to be replaced. Interior is not bad. Dash has big hole in the top middle where a speaker used to be I guess. Door panel plastic is very faded. Interior electrics all seem to work. Passenger power window regulator is bad.
PO bought the truck from TX with a bad motor. He sourced another IDI from a salvage yard and installed himself. Supposedly drove the truck and said it didn't run right, so he pulled the injectors and cleaned them. Re-installed injectors and couldn't get it to start. Replaced the injection pump and still wouldn't start. Then he sold it to me.
I verified fuel is getting to the injectors. Cleaned up the injector seats and installed new injectors. Compression test showed 300-350 psi on pass side cyls, and 150-200 on driver side cyls. There's a big thread with all details here: http://www.oilburners.net/forums/showthread.php?t=32218&highlight=newb+questions
I put the following parts into it:
- (1) new heavy duty battery (other battery tested good)
- (8) new Delphi injectors tested and pop matched by typ4
- (8) new Beru glow plugs
- new return line kit
- ignition cylinder in steering column
Previous owner put the following parts in it:
- reman'd injection pump
- glow plug controller
![dunno :dunno :dunno](/styles/default/xenforo/smilies/shrug.gif)
