rubberfish
Good to hear George
Hey, which model is that, that failed?
Agnem said:Sorry to hear about the bum luck Geo. Glad they got you covered though. When I first started to read your post, I was afraid you were going to say something like your bell housing weld let go. I'm intrigued by their claim that faulty injector firing can ruin one of their disks. I guess it seems possible, but I dunno. Anyway, here's hoping it goes back together for you as quick and easy as it came apart.
rubberfish said:Good to hear George
argve said:George,
Mine is a SBC CON O - problem that I have is the clutch won't last more than about 15-20k miles (even less if I drove harder). It just can't hold the power that I'm putting down for long periods of time. I've had 2 SBC in it so far and each one dies a pretty quick death - I'm on borrowed time at this point on this clutch - I can't lay in to it too hard at this point. I have talked with some local SBC dealers and Peter I get the same response from all of them that is I need to step up the clutch because the std diameter clutch is just not enough for me but at the cost of adding the extra diameter is too high for my blood (read I'm a poor boy)... So I just live with the fact that I can't pour all the power to the coals and when towing I have to take it real easy.
It's gotten worse since I added the locker rear end because now the tires hold more traction so that means the clutch has to work harder
geonc said:'98 Dodge Ram 2500.......24 valve Kuminski
geonc said:NOW mebee I can get to the other packages that "BROWN" :Sly has been delivering
rubberfish said:Good to hear George,
You're never gonna guess what happened
to me while I was moving into my new house
and shop. Very similiar to your gong show.
A loud shriek, hard pedal for a moment.
I'll post the pics this evening.
12,000 kms - about 8,500 mi ??? or so.
Bob
'92 K2500*GMCummins*Special Edition*Intercooled 12Valve*KDPfixed
4”Pipe*5”Tip*O-Ringed Head*BHAF*4000GSK*0 plate*370’s*BD Gauges
BD Pump*Southbend Clutch*NV4500*6”Susp Lift*LT315’s and only 6400lbs.
