THSIM9’s 1991 F250 Project
I converted to serp belt for that very reason. The less fab work I have to do the happier I am.
THSIM9
Idaho
I would like to do this someday. How did you tackle it? Did you get a donor engine or just buy all the components new?
Facebook marketplace and Craigslist mostly.
I actually have an almost complete set to do another serpentine setup, the tensioner peg hole needs repaired in the one bracket, and the vac pump pulley is missing, but if you're interested in it you're welcome to it
THSIM9
Idaho
Anyone have any ideas or information on the best place to put the port for the boost gauge? I’m using a CDD intercooler and V-banded intake manifold and there is no provision for a sender. I was thinking in the cold side piping right above the V-band, I think I can weld a bung on there for the tube to run my mechanical gauge.
hacked89
Bucks County PA
That’s where I put mine on a truck that had the same components
The_Josh_Bear
Western WA
That's were I have mine, too. I didn't want to bother welding the thin SS so I just drilled it, tapped it gently and set the 1/8 NPT with RTV. No issues after years.
Mine is tapped to the fitting where the wastegate line normally hooks up to, but since don't need the wastegate...
THSIM9
Idaho
Still plugging along getting stuff put back together. Got the serpentine setup from @Nero installed minus the power steering pump and vacuum pump. Hood is back on, cooling system is completely back together. Fixed my parking brake linkage, and started to layout my custom gauge setup.
The progress these days is a lot less **** than when I was putting the engine together or bolting on the turbo and other goodies but we are getting closer to startup every time I work on it!
DaveBen
Ukiah, Ca
You will need a temp gauge to see if you are running cool enough. With that aluminum radiator you should have no problem.
THSIM9
Idaho
I have one. I just pulled 3 random 2 1/16 gauges out for layout. In the dash will be speed, tach, oil pressure, water temp, and volts, the pillar will be pyro, Boost and fuel level.
Oh dang, didnt waste any time installing that setup.
Was the tensioner bit hard to fix?
THSIM9
Idaho
Not gonna lie I didn’t even notice anything wrong with it. I bought a tensioner and an idler pulley and bolted them on with no issues. The groove almost looked intentional so I left it. I haven’t put the belt on yet though so maybe it is going to cause an issue.
Luckily the father in law is a damn good welder and has multiple different machines so I’m sure we can get it fixed up if necessary. I can stick stuff together if i can use a mig machine but that’s the extent of my welding skill.
Bichn' hope it all goes off without a hitch. Looking good so far
Vincent
