LCAM-01XA
Alrightie, I'll actually be starting on wiring the new setup in a few, then she goes on a test drive to the gas station and results will be posted here along with wiring diagrams and such
Actually the trick with the PSDs is to feed the PCM a dummy signal, I have that setup in my truck (the 22k resistor) and I got the idea from a 2000 PSD with a manual converter control. So as long as the PCM receives that signal, it will be happy, as it thinks the converter is still under its control (at least the 7.3 PCMs do that).
this is a great thread and the diagrams are great. Let's finish hashing it out, and then if Goofy would like to repost with the diagrams (and proper credit of course) we can convert it to a tech article.
Well I did it, and it works. Additionally to 1st and 2nd gear, SS1 is active in park, reverse, and neutral, so which allows the TC to be locked only in 3rd and 4th. I'll get into details a bit later on as right now I got a driveshaft that needs the U-joints replaced...
But, with respect to what OldBull8 posted last about the 4R100 transmission - the E4OD has only one purple wire with yellow tracer, there's only one more purple wire in the harness but it has an orange tracer and it's used to ground SS2.
Oh, good to know thenThe extra wires on the 4R100 are for the TSS and OSS. The PCM uses those in addition to the VSS to determine converter lock up.
For the E4OD just do what you did.
In all honesty I don't think it would be easy to pre-make a harness for this - for one thing everyone likes their switch at a different location, for instance mine is on the shifter but that's cause I welded up a little bracket for it there, while most folks seem to like them on the dash somewhere. Then there's the matter where you want the LEDs, and so on... However when we're done with this subject here you will have detailed instructions and diagrams to make your own harness and run it any which way you please, along with at least two options as far as manual switch setup goes (on/off or on/off/auto)... I'm working on this already, so hold on for a bit moreSo if I send you some relay pigtails and a little cash you will make a harness with installation instructions for me right
I know it was a joke, but it was also a perfectly legit questionMan... jk I was kinda giving you a hard time, I was only a little serious
Very nice write up. Excellent circuit pix.
Tech Article please.
