Well, I hit the bare metal with POR metal prep. I tend to spray it on, let it soak, spray it again and work it in with a scotchbrite pad trying to really get it into the pits I can't get clean and then just repeat a few times keeping it wet. I try not to let it dry. Then I hosed it off and dried it with dry air. My refrigerated dryer is pretty awesome. ;sweet
I cleaned the edges back and hit them with some weld through primer and then put some pieces in to tie the rocker back to the B pilar and rear cab metal.
I left the gaps on purpose. I want to get paint/coating in there and I will be cutting a couple more holes up higher so I can really get paint in there. Need to shoot a little paint up in the door post area and then weld that post patch in. Paint and close it up. Then cut out the back section and clean and fill it.
Next dilemma is when to order the engine. I almost want to have it installed before I paint. I'm real nervous about assembling the front clip post paint even though I suspect I could do a better job on the paint that way. I just never have any help and I can't imagine putting a painted hood on alone. If I want the engine in place before paint, I'm about there.
Weather is supposed to be decent. Maybe I can pick up the pace a bit.
