What are your drive pressures at?
Im doing the same thing your trying to do though I’m going to be monitoring a lot more things and I’m working on getting a layout figured out for a 3.5” lcd as the character display is just to blah for my liking. I may use 9 separate oled displays instead of the lcd for better daylight viewing.
This is using ford sensors,
Version 1 still on the 3D printer
Version 2 made out of abs on the 3D printer
Oled display that I may use
Look up the chip below, it’s a 8 channel in to 1 channel output analog switch, these are cheap and allow you to expand your ADC inputs.
MC74HC4851A
Post up your results when you get them, I’ll be interested to see what others are running.I haven’t actually installed the sensor into the exhaust manifold yet, that’s my project for next week.
Just like boost pressure is the pressure ahead of the compressor wheel feeding the intake, drive pressure is the opposite so it’s the pressure of the exhaust gasses ahead of the exhaust stroke pushing against the turbine wheel. Drive pressure ratio is the ratio of boost/drive pressure, and ideally you want it to be 1:1 in a perfect world, but under 1.5:1 is pretty good as far as turbo efficiency.Wes, what’s the difference between boost pressure and drive pressure. I’ve heard this term, but don’t really understand what it is. I get what boost is,....
That's some cool stuff you're doing...Any chance that you will be making some of those "digital dashes" available for the rest of us, in the future...possibly?
Really diggin' that "version 2"!!!
What he said. Depending on the display size, more than likely, I'd buy a kit if you offered one.
Have you seen this?
https://www.gofundme.com/obs-digital-dashboard
Not intending to hijack this th thread...hoping to add to the conversation.
hang on ...gots to git up on me soap box...ahh thets better...
I must say that I am (and maybe others) somewhat enamored by the sweep of an analog tach......and the factory zpeedo seems to work well for me too.
However, WE ALL KNOW that the rest o' the factory offerings to the left of the cluster...are lackluster.
Seems that a drop-in left side...upgrade....would be...just like that V-2. Thanks fer lettin me share!
Til next time...
I'm a analog fan! Having a multi function digital display solves the space problem. Also, my aging eyes have difficulty quickly reading my autometer gauges. Especially since they have the nasty habit of fogging up
