1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
My arduino gauge project
Discussion in '6.9L IH & 7.3L IDI Diesels' started by Jubjub, Aug 26, 2019.
  1. dgr
    dgr Full Access Member
    879
    220
    Aug 5, 2012
    sac town
  2. ifrythings
    ifrythings Full Access Member
    637
    387
    Dec 17, 2011
    BC
    I’m using an exhaust back pressure sensor from a 7.3 powerstroke, they go up 40psi and will read vacuum too.
    Pulled a bunch out of the wreckers, not all of them were good though, 7.3 ones are 1/8” npt, 6.0l and 6.4l are some flare thing and can read pressures up to 75-80psi. The bottom right is a map sensors for a 6.4L which is an o-ring seal with metric threads and reads up to 75-80psi
  3. nightrunner84
    nightrunner84 Full Access Member
    95
    6
    Dec 11, 2007
    Dayton, Ohio
    I'm going to make a bracket to carry the spare under the rear tank. It'll hang a little low, but the plan is to drag a 5th wheel long distance with my kids. I WILL have a spare.
    dgr likes this.
  4. nightrunner84
    95
    6
    Dec 11, 2007
    Dayton, Ohio
    Sorry it's been a while. I got the permanent circuit built, and it seems to work. Still need to add two more data fields, one for pressure, and one for temp. Here is the board I made from Ifrythings drawing. The trans temp field is missing the powered portion because, as he said, the temp sensor in the trans can be tapped.
    Also, I found this bezel on Thingiverse. It'll be going into the overhead console I'm building.
    Also, intercooler......
    bbjordan, chillman88 and dgr like this.
Share This Page
