My arduino gauge project
ifrythings
BC
Try this code, I added the serial monitor to it so make sure yours is set to 9600 or change the code to whatever speed you would like. I also added another lcd pinout in the code, you may have to run an I2C(IIC) scanner program to find the address of your screen if the default 0x20 doesn't work. If you find the correct address and you still don't get a display you will have to look up the chip on the small board on the back of your lcd and test where which pins of the chip hookup to which pins of the LCD (it's not as bad as it sounds to do)
Also fixed a miss type where the engine oil pressure would display engine oil temperature (around line 200)
Code:
/*                                         ARDUINO NANO
 *                                       ------|USB|------
 *                             NOT USED <|D13  |___|  D12|> NOT USED
 *        BAD 3.3VOLT OUTPUT, NEVER USE <|3V3         D11|> NOT USED
 *                             NOT USED <|AREF        D10|> NOT USED
 *                 ANALOG INPUT FOR ECT <|A0           D9|> NOT USED
 *                 ANALOG INPUT FOR EOT <|A1           D8|> NOT USED
 *                 ANALOG INPUT FOR TOT <|A2           D7|> NOT USED
 *                 ANALOG INPUT FOR EOP <|A3           D6|> NOT USED
 *                              IIC SDA <|A4           D5|> NOT USED
 *                              IIC SCL <|A5           D4|> DIGITAL OUTPUT FOR COLD TIMING ADVANCE SOLENOID
 *                             NOT USED <|A6           D3|> DIGITAL OUTPUT FOR HIGH IDLE SOLENOID
 *                             NOT USED <|A7           D2|> DIGITAL INPUT FOR MANUAL HIGH IDLE SWITCH
 *                               5V OUT <|5V          GND|> GROUND
 *                             NOT USED <|RESET     RESET|> NOT USED
 *                               GROUND <|GND         RX |> NOT USED
 *                             POWER IN <|VIN         TX |> NOT USED
//Libraries
#include <LiquidCrystal_I2C.h>
// Set the LCD I2C address and pinout
//                 address,EN,RW,RS,D4,D5,D6,D6,BL,Polarity
LiquidCrystal_I2C lcd(0x20, 2, 1, 0, 3, 1, 5, 6, 4, NEGATIVE); // new
//LiquidCrystal_I2C lcd(0x20, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE); // old
// ADC
// NOTE: This section is to calibrate the Analog to Digital Converter
// NOTE2: The ADC is only capable of reading VREF - 1 count. EXP. if VREF = 5V, ADC will return 4.995V (See datasheet for reason why)
#define VREF 5.003 // Measued the value of 5 volt pin and enter it here
#define ADC_V VREF/1024.0 // Take the reference voltage and divide by the amount of steps the ADC has
// Input Declarations
// Analog
#define ECT A0 // Engine Coolant Temperatur Sensor connected to Analog pin 0
#define EOT A1 // Enigne Oil Temperature Sensor connected to Analog pin 1
#define TOT A2 // Transmission Oil Temperature Sensor connected to Analog pin 2
#define EOP A3 // Engine Oil Pressure Sensor connected to Analog pin 3
// Digital
#define MHI 2 // Manual High Idle Switch connected to Digital pin 2
// Output Declarations
// Digital
#define High_Idle 3 // High Idle Solenoid connected to Digital Outpput pin 3
#define Cold_Adv  4 // Cold timing Advance Solenoid connected to Digital Output pin 4
// Variables
signed int ect_t = 0; // Engine Coolant Temperature
signed int eot_t = 0; // Engine Oil Temperature
signed int tot_t = 0; // Transmission Oil Temperature
int eop_p = 0; // Engine Oil Pressure
int eop_v = 0; // Engine Oil Pressure Voltage
byte MHI_Switch = 0; // Manual High Idle Switch
unsigned long last_time = millis(); // Used to hold the previous time the LCD was updated
unsigned long last_time_serial = millis(); // Used to hold the previous time the Serial Monitor was updated
//Custom °F symbol for character display
byte degtempF[8] = {
  B11000, // HH...
  B11000, // HH...
  B00111, // ..HHH
  B00100, // ..H..
  B00110, // ..HH.
  B00100, // ..H..
  B00100, // ..H..
  B00000, // .....
// Ford Temperature sensor lookup table in °F
// NOTE: "PROGMEM const" is required so the lookup table doesn't get loaded into ram
//       as that would use up all the ram, instead acess the lookup table from flash memory
PROGMEM const signed int Temp_ConvF[] = {
  302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302,
  302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 302, 300,
  298, 295, 293, 291, 289, 288, 286, 282, 280, 279, 277, 275, 273, 270, 268,
  266, 264, 263, 262, 261, 260, 259, 257, 255, 254, 253, 252, 251, 250, 248,
  247, 246, 245, 244, 243, 241, 240, 239, 237, 236, 235, 234, 233, 232, 231,
  230, 229, 228, 227, 226, 226, 225, 224, 223, 222, 221, 221, 220, 219, 218,
  217, 217, 216, 216, 215, 214, 213, 212, 212, 211, 210, 209, 208, 208, 208,
  207, 206, 205, 204, 203, 203, 202, 201, 201, 200, 200, 199, 199, 199, 198,
  198, 197, 197, 196, 196, 195, 194, 194, 193, 193, 192, 192, 191, 191, 190,
  190, 190, 189, 189, 188, 188, 187, 187, 186, 185, 185, 184, 184, 183, 183,
  182, 182, 181, 181, 181, 180, 180, 179, 178, 178, 177, 177, 176, 176, 175,
  175, 174, 174, 174, 173, 173, 172, 172, 172, 172, 172, 171, 171, 171, 170,
  170, 169, 169, 169, 168, 168, 167, 167, 167, 166, 166, 165, 165, 165, 164,
  164, 163, 163, 163, 163, 163, 162, 162, 162, 161, 161, 160, 160, 160, 159,
  159, 158, 158, 158, 157, 157, 157, 156, 156, 156, 156, 155, 155, 155, 155,
  154, 154, 154, 154, 154, 154, 154, 154, 154, 153, 153, 153, 153, 152, 152,
  152, 151, 151, 151, 151, 150, 150, 150, 150, 149, 149, 149, 149, 148, 148,
  148, 147, 147, 147, 147, 146, 146, 146, 146, 145, 145, 145, 145, 145, 145,
  145, 144, 144, 144, 144, 143, 143, 143, 143, 142, 142, 142, 142, 141, 141,
  141, 141, 140, 140, 140, 140, 139, 139, 139, 138, 138, 138, 138, 137, 137,
  137, 137, 136, 136, 136, 136, 136, 136, 136, 136, 135, 135, 135, 135, 134,
  134, 134, 134, 133, 133, 133, 133, 132, 132, 132, 132, 131, 131, 131, 131,
  130, 130, 130, 129, 129, 129, 129, 128, 128, 128, 128, 127, 127, 127, 127,
  127, 127, 127, 127, 126, 126, 126, 126, 125, 125, 125, 125, 124, 124, 124,
  124, 123, 123, 123, 123, 122, 122, 122, 122, 121, 121, 121, 120, 120, 120,
  120, 119, 119, 119, 119, 118, 118, 118, 118, 118, 118, 118, 118, 117, 117,
  117, 117, 116, 116, 116, 116, 115, 115, 115, 115, 114, 114, 114, 114, 113,
  113, 113, 113, 112, 112, 112, 111, 111, 111, 111, 110, 110, 110, 110, 109,
  109, 109, 109, 109, 109, 109, 109, 108, 108, 108, 108, 107, 107, 107, 107,
  106, 106, 106, 106, 105, 105, 105, 105, 104, 104, 104, 104, 103, 103, 103,
  103, 102, 102, 102, 102, 102, 101, 101, 101, 101, 101, 100, 100, 100, 100,
  100, 100, 100, 100, 100, 100,  99,  99,  99,  99,  99,  98,  98,  98,  98,
   98,  97,  97,  97,  97,  97,  96,  96,  96,  96,  96,  95,  95,  95,  95,
   95,  94,  94,  94,  94,  94,  93,  93,  93,  93,  93,  92,  92,  92,  92,
   92,  91,  91,  91,  91,  91,  91,  91,  91,  91,  91,  90,  90,  90,  90,
   90,  89,  89,  89,  89,  89,  88,  88,  88,  88,  88,  87,  87,  87,  87,
   87,  86,  86,  86,  86,  86,  85,  85,  85,  85,  85,  84,  84,  84,  84,
   84,  83,  83,  83,  83,  83,  82,  82,  82,  82,  82,  82,  82,  82,  82,
   82,  81,  81,  81,  81,  81,  80,  80,  80,  80,  80,  79,  79,  79,  79,
   79,  78,  78,  78,  78,  78,  77,  77,  77,  77,  77,  76,  76,  76,  76,
   76,  75,  75,  75,  75,  75,  74,  74,  74,  74,  74,  73,  73,  73,  73,
   73,  73,  73,  73,  73,  73,  72,  72,  72,  72,  72,  71,  71,  71,  71,
   71,  70,  70,  70,  70,  70,  69,  69,  69,  69,  69,  68,  68,  68,  68,
   68,  67,  67,  67,  67,  66,  66,  66,  66,  66,  65,  65,  65,  65,  64,
   64,  64,  64,  64,  64,  64,  64,  64,  63,  63,  63,  63,  63,  62,  62,
   62,  62,  61,  61,  61,  61,  61,  60,  60,  60,  60,  59,  59,  59,  59,
   59,  58,  58,  58,  58,  58,  57,  57,  57,  57,  57,  56,  56,  56,  56,
   55,  55,  55,  55,  55,  55,  55,  55,  55,  54,  54,  54,  54,  54,  53,
   53,  53,  53,  52,  52,  52,  52,  52,  51,  51,  51,  51,  50,  50,  50,
   50,  50,  49,  49,  49,  49,  48,  48,  48,  48,  47,  47,  47,  47,  46,
   46,  46,  46,  46,  46,  46,  46,  45,  45,  45,  45,  44,  44,  44,  44,
   43,  43,  43,  43,  42,  42,  42,  42,  41,  41,  41,  41,  40,  40,  40,
   40,  39,  39,  39,  39,  38,  38,  38,  37,  37,  37,  37,  37,  37,  37,
   36,  36,  36,  36,  35,  35,  35,  35,  34,  34,  34,  34,  33,  33,  33,
   32,  32,  32,  32,  31,  31,  31,  30,  30,  30,  29,  29,  29,  28,  28,
   28,  28,  28,  28,  27,  27,  27,  26,  26,  26,  25,  25,  25,  24,  24,
   24,  23,  23,  23,  22,  22,  22,  21,  21,  21,  20,  20,  20,  19,  19,
   19,  19,  18,  18,  18,  17,  17,  17,  16,  16,  16,  15,  15,  15,  14,
   14,  14,  13,  13,  12,  12,  11,  11,  10,  10,  10,  10,   9,   9,   9,
    8,   8,   7,   7,   6,   6,   5,   5,   4,   4,   3,   3,   2,   2,   1,
    1,   0,   0,  -1,  -1,  -1,  -1,  -2,  -2,  -3,  -3,  -4,  -4,  -5,  -6,
   -7,  -8,  -9, -10, -10, -11, -12, -13, -14, -15, -16, -17, -17, -18, -19,
  -19, -20, -21, -22, -23, -24, -25, -26, -27, -27, -28, -28, -29, -30, -31,
  -32, -33, -34, -35, -36, -37, -37, -38, -39, -40, -40, -40, -40, -40, -40,
  -40, -40, -40, -40, -40, -40, -40, -40, -40, -40, -40, -40, -40, -40, -40,
  -40, -40, -40, -40,
// Note: "pgm_read_word" is needed so we can access the lookup table from flash memory
void Get_Sensors() {
  ect_t = analogRead(ECT); // Get Engine Coolant Temperature ADC value
  ect_t = pgm_read_word(&Temp_ConvF [ect_t]); // Lookup ADC value to temperature
  eot_t = analogRead(EOT); // Get Engine Oil Temperature ADC value
  eot_t = pgm_read_word(&Temp_ConvF [eot_t]); // Lookup ADC value to temperature
  tot_t = analogRead(TOT); // Get Transmission Oil Temperature ADC value
  tot_t = pgm_read_word(&Temp_ConvF [tot_t]); // Lookup ADC value to temperature
  eop_p = analogRead(EOP); // Get Engine Oil Pressure ADC value
  eop_v = eop_p * ADC_V; // Calculate to voltage
  eop_p *= 0.030887; // Calculate to pressure
  eop_p -= 20.826; // Subtract offset
} // End of Get_Sensors Function
// LCD layout for referance
    Postion
    12345678901234567890
L 1*ECT:###F
I 2*EOT:###F
N 3*TOT:###F
E 4*EOP:###Psi
void LCD_Update() {
  lcd.setCursor(0, 0); // First line, postion 1
  lcd.print("ECT:"); // Write ECT: to Lcd
  lcd.print(ect_t); // Write Engine Coolant Temperature to Lcd
  lcd.write(byte(0)); // Write °F
  lcd.print(" "); // Clear extra charaters when going from 3 to 2 digit
  lcd.setCursor(0, 1); // Second line, postion 1
  lcd.print("EOT:"); // Write EOT: to Lcd
  lcd.print(eot_t); // Write Engine Oil Temperature to Lcd
  lcd.setCursor(0, 2); // Third line, postion 1
  lcd.print("TOT:"); // Write TOT: to Lcd
  lcd.print(tot_t); // Write Transmission Oil Temperature to Lcd
  lcd.setCursor(0, 4); // Fourth line, postion 1
  lcd.print("EOP:"); // Write EOP: to Lcd
  lcd.print(eop_p); // Write Engine Oil Pressure to Lcd
  lcd.print("Psi"); // Write Psi to Lcd
} // End of LCD_Update Function
// This only runs once on intial power on
void setup() {
  pinMode(High_Idle, OUTPUT); // Set High Idle as Output
  pinMode(Cold_Adv, OUTPUT); // Set Cold Timing Advance as Output
  pinMode(MHI_Switch, INPUT); // Set Manual High Idle Switch as Input
  digitalWrite(High_Idle, HIGH); // Set the inital High Idle Solenoid state to on
  digitalWrite(Cold_Adv, HIGH); // Set the intial Cold Timing Advance Solenoid to on
  Serial.begin(9600); // Serial Monitor set to 9600 Buad
// Setup the LCD
  lcd.begin(20, 4); // Init the LCD for 20 chars and 4 lines
  lcd.setBacklight (HIGH); // Turn LCD backlight on
  lcd.createChar(0, degtempF); // Load custom °F character into LCD
  lcd.home(); // Go to line 1, postion 1
} // End of setup function
void loop() {
  Get_Sensors(); // This updates the sensors valves in ram, this runs very fast!
  if(millis() - last_time >= 100){ // If 100mS has elapsed update the LCD (10 updates per second)
    LCD_Update(); // Update LCD
    last_time = millis(); // Set to current time so it can be rechecked above
  } // End of LCD update
// High Idle and Cold Timing Advance on below 120°F Engine Coolant Temperature
  MHI_Switch = digitalRead(MHI); // Read the state of the Manual High Idle Switch
  if (MHI_Switch == HIGH) digitalWrite(High_Idle, HIGH); // If Manual High Idle switch is on, turn on High Idle solenoid
  else if (ect_t > 120) digitalWrite(High_Idle, LOW); // High Idle Solenoid is off if Engine Coolant Temperature is higher than 120°F
  if (ect_t > 120) digitalWrite(Cold_Adv, LOW); // Cold Timing Advance Solenoid is off if Engine Coolant Temperature is higher than 120°F
  if(millis() - last_time_serial >= 1000){ // If 1000mS has elapsed update the Serial Monitor (1 updates per second)
    Serial.print("ECT:");
    Serial.print(ect_t);
    Serial.println("F");
    Serial.print("EOT:");
    Serial.print(eot_t);
    Serial.print("TOT:");
    Serial.print(tot_t);
    Serial.print("EOP:");
    Serial.print(eop_p);
    Serial.println("Psi");
    Serial.println(" ");
    last_time_serial = millis(); // Set to current time so it can be rechecked above
  } // End of Serial Monitor update
} // End of loop Function
nightrunner84
Dayton, Ohio
Thanks! It compiled and uploaded. I've got data in the serial monitor now. The display is still inop, but maybe I got a bad screen. Let me check on a couple of things......
Thank you! I showed some people at Christmas what you're doing, they thought it was really cool.
ifrythings
BC
Thanks!
Try running this sketch, it will tell you the I2C address of your screen in the serial monitor
Code:
// i2c_scanner
// Version 1
//    This program (or code that looks like it)
//    can be found in many places.
//    For example on the Arduino.cc forum.
//    The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
//     Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26  2013
//    V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
//    by Arduino.cc user Krodal.
//    Changes by louarnold removed.
//    Scanning addresses changed from 0...127 to 1...119,
//    according to the i2c scanner by Nick Gammon
//    https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
//    As version 4, but address scans now to 127.
//    A sensor seems to use address 120.
// Version 6, November 27, 2015.
//    Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
void setup()
  Wire.begin();
  Serial.begin(9600);
  while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
void loop()
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
On mine it tells me the address is 0x20, if yours is different change it in this line of code under the address spot.
Code:
Can you also snap a very clear shot of the chip on that small board on the back of your screen, if you get your address right above and it still doesn't work then we need to make sure the pinout in the code matches the chip on that board.
It should look like this when it works
ifrythings
BC
@nightrunner84
I think I have the same screen board that you have, try this and see if your screen works
Code:
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
nightrunner84
Dayton, Ohio
Alright! Up and running!
I ran the script you gave me, it gave me 0x3F. Changed the address from 0x27 to 0x3F.
Thank you for the time spent on figuring this out. I couldn't have done it without your help.
nightrunner84
Dayton, Ohio
Well, shoot. I plugged in a NTC type sensor, and the all went to -40. The resistance was checked against a resistance table, and made sense (8.3k for around 85 degrees F). I doesn't matter which pin I put it on (A0-A3), all the fields change to the displayed picture below. I'm using the 5V pin and running that through the sensor, back to an analog pin. Did I hook it up wrong?
ifrythings
BC
The program I gave you is designed to read the 2 wire Ford sensors, you will need the circuit below and a Ford sensor for this to work. You only need one "Signal Ground" wire that all your sensors can share, the reason for a separate return ground is to prevent ground current loops from forming and messing up the readings and/or injecting large amounts of noise into your micro.
Note: All resistors are 1% tolerance or better.
Note2: Do not use this circuit when trying to read the E4OD internal temperature sensor as the TECA already has the biasing circuit in it, just use the 100nF cap, 10K resistor and 10nF cap when tapping into the E4OD TOT wire.
As for all the displays changing at once, that is normal when nothing is hooked up, the way the ADC works is it connects a internal sampling capacitor to each pin for a small amount of time than disconnects it and reads the capacitor. When it reads the pin you have something hooked up, it charges the capacitor, when you read the next pin with nothing connected to it nothing changes the charge on the capacitor and it will read the same thing as the last pin and etc.
nightrunner84
Dayton, Ohio
OK, I've built one of the filters. It works! Now to build some more, and get the sensors. Thanks for the filter design!
Charles Moore
Minneapolis, MN
This is amazing. Keep up the awesome work guys. I'm following this project for sure.
I'd love to be able to monitor & data log various engine sensors and my electrical usage of my PV system.
nightrunner84
Dayton, Ohio
I'm building the electronics for the sensors right now. The PCB and terminals came in yesterday. Should be done around the end of the week.
The credit for ALL of this belongs to ifrythings. There's no way I could do this on my own.
ifrythings
BC
I’ve been playing around with the data logging and it does work, it puts everything in a text file that’s comma separated, every second it starts a new line and records the values, pretty easy to use.
Thanks, post some pics of your pcb when your done. Have you added anything else to the design?
nightrunner84
Dayton, Ohio
No, I don't have the intelligence to add anything original. I do want to add two extra fields. Fuel temp and pressure, diff/coolant/trans temps, and oil pressure, it where I want to end up.
The fuel temp thing is for the WMO. We changed the rear tank to the 38 gallon version. That's 10 feet of coiled copper inside that tank, it's going in line with the heater core, assuming the pump can move coolant through about 40 feet of pipe. The bulkhead adapters I made are ground flat between them, and a sheet of gasket material is between the plates and the tanks. I want to use 100% WMO to run on.
The compression fittings are used so that there isn't any connections inside the tank that could leak. The copper lines go straight through, into the tank, without any connections.
ifrythings
BC
I don’t know a whole lot about running wmo but besides monitoring fuel send temp, do you need to monitor anything else? You could monitor any or all of these, coolant send, coolant return, tank temp, fuel send temp and fuel return temp.
I made a quick diagnosis page on my screen a while back of the things I’m going to monitor, most of it is just cause I can.
here’s the 3 pages I have on the screen now
nightrunner84
Dayton, Ohio
Are you using the GM oil pressure sensor for the fuel pressure?
I'm just looking at the rear tank temp, and gambling the fuel has enough density to keep it's temp through the fuel lines, all the way to the IP. Monitoring fuel pressure is just to make sure it's not restricted.
I've ran 100% WMO for years in the brown truck, even in winter. It's a ZF5, and I changed the radiator to one from an automatic. The lines are ran through the trans cooler to heat it before it hits the filter. It works great.
On a side note, I've contacted the IRS, and asked them about the fuel taxes. Their opinion was that it was a "blended fuel" even though it's 100% WMO. They said that there are no taxes due unless I go over 400 gallons per year. Ohio sent me a tax form, and I prepay the tax when I bring it in, before it goes in the truck. It's 47 cents per gallon, and its paid on ALL the fuel I use. My hope is that it'll bulletproof me if I get dipped, as all the laws have been followed.
