Don't get me wrong, the push button was easy enough and simple enough. It just gets tiring having to explain to the wife(or anyone else that's mechanically uninclined) what to push, how long to hold it, and why you have to do such a thing.
and why I have the old pile
and why I have so many vehicles
and why the house isn't finished
and why can't I just be normal.......
I know that it has been a few months on this...but...if explaining things get a little tiring for you, why not make it a little more interesting..?Don't get me wrong, the push button was easy enough and simple enough. It just gets tiring having to explain to the wife(or anyone else that's mechanically uninclined) what to push, how long to hold it, and why you have to do such a thing.
They used to last that long, but not seeing anywhere near that with current beru plugs.Keep spitballing.
Dual coil plugs and a pushbutton are much cheaper then an OE controller and zd9 plugs. That's why I went with it. And that OE system isn't going to make it to 100k miles, unless you start it once and run the thing continuously until you hit that 100k miles![]()
My zd9 plugs from oriellys have 50,000 miles on them. Starts up perfectly fine down to 10deg. When they start to show wear I’ll replace them under warranty and not pay a dime and my controller has 95,000 miles on it. I can afford $80 every 90,0000 miles for a new controller. Just take care of your stuff. These trucks ran great from the factory. With a few basic mods like turbos, turned up fuel 1-2 flats to match turbo, timing, moving the controller off the fire wall and basic maintenance the stock systems work fine with out hacking up the harness or adding buttons and switches.Keep spitballing.
I disagree.My zd9 plugs from oriellys have 50,000 miles on them. Starts up perfectly fine down to 10deg. When they start to show wear I’ll replace them under warranty and not pay a dime and my controller has 95,000 miles on it. I can afford $80 every 90,0000 miles for a new controller. Just take care of your stuff. These trucks ran great from the factory. With a few basic mods like turbos, turned up fuel 1-2 flats to match turbo, timing, moving the controller off the fire wall and basic maintenance the stock systems work fine with out hacking up the harness or adding buttons and switches.
I'm not either. And that's with OE parts from the dealer, on rigs that have decent wiring and batteries.They used to last that long, but not seeing anywhere near that with current beru plugs.
