Finally.................... I think it's finally finished! I certainly hope so anyway. If you missed the previous updates, they are linked below:
Start Here
Second Update
Third Update
Fourth Update
Fifth Update
Sixth Update
Seventh Update
Eighth Update
Ninth Update
Tenth Update
Just as a final tally of parts and their cost, here's the list (it's a little scarey):
Machine work and installation of new cam bearings $1100 ($220 of that was balancing work)
Gasket set and valley pan (Victor Rienz) $250
Clevite 77 rod and main bearings $314.25
Mahle reduced compression pistons with rings, pins, clips $550
"typ4" cam $200
New Ford lifters $90 (eBay find)
Intake vavles (Perfect Circle) $75
Exhaust valves (EngineTech Stelitte face) $105
Comp cam 910 springs $81
Rear main seal with repair sleeve $42
Head work (had to be redone, 1st shop didn't do what they said they did) $410.26
ARP head studs $215
7.3 PSD intercooler $200
Intake hat $66
Intercooler piping/boots $194
Moose pump $689
Moose injectors $1085
Water pump (new Ford) $95
Head dowels $12.50
New 7.3 rockers (Melling) $95.92
Rodney Red Radiator $750
Total = $6619.67
Here is the finished radiator support. It's now widend 1.5 inches, painted, and ready to go back on the truck with the rest of the front clip. Again, this was done to make room for the '99-'03 PSD intercooler without having to ditch/cut the stock trim/valance.
Front clip back on the truck (yet again).
Rodney Red installed and a clearence check with radiator in it's new location.
Spacers (1.5 inch) for upper radiator mounts.
More to follow:
Heath
Start Here
Second Update
Third Update
Fourth Update
Fifth Update
Sixth Update
Seventh Update
Eighth Update
Ninth Update
Tenth Update
"typ4" cam $200
ARP head studs $215
Intake hat $66
Moose pump $689
Head dowels $12.50
Total = $6619.67
More to follow:
Heath
