hesutton
The Anti-Anderson
Well, I was going to put the heads on the block this weekend, but I wanted to make sure they were ready 1st. So, I pulled the valves to make sure the machine shop did take the heads down and inspect the valves, seats, and guides like they said they did. THEY DID NOT!!!
Looking at the invoice, they didn't charge me for doing the inspection, but they told me on three separate occasions that they had.
So that means the heads need more work. The old guides need to be machined and new guides pressed in. MORE DELAYS!
Anyway, the guides are all worn with about 8-10 thousands of side play with the valves in the guides. That's too much. The intake valves are coaked from oil leaking all over them for who knows how long.
Coaking in the intake:
After cleaning:
Wear on the stems.
Pitting on the face of some of the exhaust valves:
More to follow:
Heath
Looking at the invoice, they didn't charge me for doing the inspection, but they told me on three separate occasions that they had. So that means the heads need more work. The old guides need to be machined and new guides pressed in. MORE DELAYS!
After cleaning:
Wear on the stems.
More to follow:
Heath
Those exhaust valves look terrible. Whatever the shop did on those heads sure wasn't much if anything. Chargeing you anything is questionable. If they charged you any money it would have been for rental space in their shop. I don't see any work done to the heads. They need to be completely taken down.... Cleaned... Then magnafluxed for cracks. Then repaired. Then pressure tested or at least vacuum tested. At the very least some diesel poured into the valves and seats. If it leaks thru that seat and valve are not right... With the new shop just make sure they set the valves the proper depth in the heads. I don't have the intake or exhaust valve depth but its very differant from each other.. Keep going.. Your doing a fine job of this and the pics and documantation is priceless.
