jaluhn83
Took the truck out for a test drive yesterday, finally. Was supposed to be a ~3 week project (hopefully) that turned into 2 months mainly due to the machine shop being slow.
Work that was done:
Full motor rebuild with 0.015" decked ceramic coated pistons & typ4 cam.
Semi rebuilt heads with stainless valves and performance springs. Heads were ~25k on a rebuild (from NMB4) and installed new stainless intake valves, & performance springs and shims from typ4.
HX35 turbo sitting on my original homemade mount and exhaust setup.
Frozen boost air to water intercooler
Custom intake
Full moose pump
Modified oil pan with level switch and ports for external oil cooler, aux temp sensor & oil separator drains.
Hydroboost conversion
New aluminum radiator (not originally planned but a side effect of my OEM radiator getting stolen )
Installed ZF5-S47 trans (apparently recently rebuilt but with no records)
Still have to finish installing the radiator & pump for the intercooler and rebuild the AC system
My initial impressions from driving it are pretty good. The hydro brake setup is definitely much more powerful than the vacuum unit. Almost have to relearn how to drive since the brake is so sensitive now. The HX35 screams pretty good and it seems to be much more powerful than the old setup. (semi functional Banks wg turbo) I've got some pretty good boost leaks (ran out of argon before I finished welding the intercooler pipes) and I haven't set the timing yet but she seems to make 3-5 psi empty and pulls well. Have to see how she pulls loaded once I get her broken in more.
Only real problem I've found so far is a nice oil leak from the front of the motor - either front of the oil pan or front seal and I'm guessing (and hoping) it's the seal.
I have pictures and will eventually get around to putting together a project thread... in my spare time!
Work that was done:
Custom intake
Full moose pump
